Help Passenger window won't go up!
Car  Clio Sport Replica
A problem occurred the other day on my Mk2 Ph2 Clio (51 Plate) Basically the passenger window would only go down not up, drivers side window functions fine up and down as normal :S After looking through some of the posts on here noticed a few other people have also encountered the same problem as I have, from what I gathered it could be either the motor, regulator, Switches or maybe a fuse(s). Anyways went down my local scrap yard got a Motor and Regulator to try to see if that was the problem--No luck, it was doing exactly the same only operating down as before, tried a new passenger switch as well that did nothing also :( The only thing I haven't tried is the drivers side switch other than that don't know what else it could be? I've also tested the voltage on the cable that plugs directly into the motor, there's only a current running through one of the two prongs, which suggests there's power getting to the motor down but not up. So i've seen on here the UCH box under the dash might be responsible for this lack of power to bring the window up??? Please help. PS.. sorry for the essay :p
