Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Whan i indicate left my fog lights come on aswell and start flashing! Also when the car is in reverese and i brake the fogs come on. If i put my hanbrake on the fogs then turn off.
Surely that wouldnt make different lights flash Pete, Mind you if no one has touched your lights and they are the originals then .......well dont know, A mystery
My m8 whos a mechanic has a look at it the other day n culdnt see anything wrong with it....hes as baffled bout it as i am! Thanks 4 ur help ppl n i will have another look
You will proberly find that water has got on to one of your earth points for the rear lights.
Try tracing a wire leading from one of the rear light units to the body. You should find a bolt with some wires leading to it, remove the bolt and clean the contact points.
check all the bulbs are correct and ok. check the earth to the backlights is ok.if the earth is faulty sometimes the current finds its way back to earth by going through the other bulbs so all the lights start flashing together etc.
