Hi guys, not posted for a while on here since i had my last clio.
The missus has an X plate 1.2 liberte MK2 ph1 (bubble)
has had intermittent starting problems over the past 6 months.
once a month it wouldn't start, leave it 2 mins try again and its fine.
however went to start it today and nothing (she flattened the battery trying before ringing me lol)
basic troubleshooting i have done so far
turn the ignition on but don't try to start it and engine management light goes out fine no scary lights anywhere on the dash, all looks normal
crank it over, cranks fine but doesn't fire.
with all the fans etc off you turn on the ignition and you can hear the fuel pump prime.
took a plug out and earthed it, got the missus to turn the car over but no spark (tried in the dark and there's not even a glimmer - plugs were new 10k ago and looked in pretty good shape - no oil in plug wells or on plugs anywhere, all clean as a whistle. When the engine turned over got a fine fuel mist come out of the plug hole (could smell it too) so fuelling ok
I am thinking dis pack but thought i would check on here to see if anything else is likely to cause these symptoms
anyone any ideas?
Russ
anyone any ideas?
Russ
