help with burning?!?
  Jap Shed
i have lots of videos on my pc that i want to put on dvd's i have tryed to use nero but i keep getting "burn failed " at the end.,
are there any programmes i can use for this???
ta!
  Golf R32
What are you trying to burn - I have found that sometimes nero has a hard job trying to encode avi's using certain codecs. Best bet is get a progrram like DVD Santa which that converts most formats into the required compoents for a DVD and then you can use nero to burn the dvd with no problems
MRBILLYUK
  FF Jeden Osiem Dwa
Shouldn't make any difference what codecs you have installed if your burning the avi's as data .
It could be any number of things . Cheap media , dvd burner lens dirty , with these 2 problems you usually get the message " power calibration error " .
What version of nero are you using ? Nero 6 is the best , Nero 7 has some issues with it ,if its a legitimate version you could try going to the nero website and getting the latest update .
As said you could encode the avi's into dvd format with dvd santa , i prefer winavi video convertor as its faster .
What speed is your writer , what speed are you trying to burn at , did you try reducing the speed ? What brand of discs are you using ?I always stick with discs using the Ritek g05 dye ( dark purple )
