Hi,
I’m due to get my clutch changed soon and wanted to make sure I change some of the seals as the box will be out.
I will be swapping out the rear main seal and the gearbox in using, was suggested replacing the selector seal. Does anyone have a guide to replacing the selector seal? Is this a seal you’d use (https://www.ebay.co.uk/itm/37493294...luQ2t7vQ4u&var=&widget_ver=artemis&media=COPY).
It’s also been suggested I take a look at the seals on the end of the driveshafts as they’ll be out. Does anyone have a link for the driveshaft seals?
Are there any other seals or difficult to reach parts you’d replace when you have the box out?
Thanks.
Thanks.
