helppppppp !!!
does this translate into: youve removed the catalytic converter and now your idling speed has gone funny and the engine stalls?
then I dunno how removing the cat would cause the idling to go wonkers. You need to ask somebody better qualified than me.
dror172 --- RING 01254 699896 & ASK FOR DAVE HEYES ON EXTENSION 159. explain the problem & tell him monkeyboy has told you to ring him. this guy is a genius with renaults.
thx CB1A
i reset the ecu disconnect the battry
but its not help
when the stay on neutral (or push the
clutch when i replace gear) i saw the rpm down to 500rpm and shut down
if i start without switch off
its not help
i had filter (k&m) i removed it but nothing
ill going to ren tomorrow
but im afraid cuz the chip
its not help
c
  CTR EK9 turbo
mine did this a few times. Did it smell of eggs (CAT) when it cut out? knackered lamda sensor? who knows. Mine doesnt do it anymore. I just started it back up. Gave it a few rev limiter blasts and that seemed to sort it out!
if he has taken off the CAT then what has he done with the lamda sensor ?? coz if hes disconected it then theres no readings going to the ECU from the lamda.......hence the stalling !!...........but who knows what hes on about !!! lol......................poor bloke !
