Hi-Level Input Help
Car  Skoda Fabia vRS
the pre outs on my HU arent working atm, would i be able to run a sub/amp setup off a hi level input, before i get em fixed
ive looked at some suitable amps and they all seem to have a hi-level input
i currently have my 6x9s hooked up on hi-level and ampd and it sounds fine
I run my entire system of hi-level inputs and have no probs at all. It all sounds fine just means a bit more wiring! some people say it reduces sound quality but you would need to be a perfectionist to noticwe in my opinion.
Yes I have front and rear hi-level inputs going into the amp which is 5 channel. This powers front and rear mids and tweeters and a sub in the boot.
wicked, how have you got that amp setup then ?
can you choose to just filter the sub channel ?
also, could i run my 6x9s on there amp, and a sub on a seperate amp, both feedin off my rear hi-level wiring ?
It was a little while ago that i did it but if I remember right the amp does all the filtering itself with an output for the sub. As for running two amps off the one hi-level input Im not sure. I would have thought that you could split the input into the two amps but I dont claim to be an expert!
yea im hoping you can, i think it would possibly half the signal though and both might end up sounding crap
anyone know ?
