HID Ballasts interfering with radio reception?
RDH
Anyone had this?
Fitted my HID's this morning and haven't been able to pick a single radio station up since haha.
Has
  RS 182 - Black Gold
Can with cheaper HID units.
I take it these are retro kits youve fitted?
Has
  RS 182 - Black Gold
Depending on the make of the unit, a lot are american/asian knock off units or manufactured "on the cheap".
There has been cases of them igniting and causing fires on a few forums.
RDH
Got mine off a member off here.
Doesn't seem to be doing it as much now I've changed my ariel (even though it is to a smaller one)
Was just wondering if it was a common problem.
  PH1 172 Sport
Just noticed mine is doing this. Are there any possible fixes, like issolate the case of the ballast from the car etc?
  Bus w**ker
Not happening for me. Where have you mounted the ballasts and how have you fixed them?
  Mondeo TDCI 130
Basically no, me and gaz have tried all things on his 197! Given up, looking for some gen 197 xenons.
Had the bumper off more times than silly mick!
  PH1 172 Sport
One is bolted to the engine fuse box and the other is bolted to the passenger wheel arch where the carbon canister normally is
  Mondeo TDCI 130
We moved the ballasts, wired them to a seperate battery to check for loom interference, wrapped them in foil, tried everything!
Nothing works.
Gaz_
  Extreme mode
Bin might work? I blame the hid's4poo ballasts, it even f**ks up the workshop radio!!! PMSL!!!
I've contacted them, and they say my car is 'sensitive' PMSL!!! Here's the thing, Andy kev Birchdown has a set in his Phase 1 with nay bother, Biohzrd has some in his MK3 with nay bother, both non hid4u kits. Cheapy chongpetang ballasts imo
  PH1 172 Sport
As much as I would like to bin them I like them too much when its dark! My radio reception is terrible before I turn the lights on anyway so theres definately something else that needs looking as as well. Luckily I dont really listen to the radio that much but its still annoying.
Gaz_
  Extreme mode
Knows, i wanna bin mine, but love the look. The interference is REALLY bad on light start up, but does come back.... just annoyingly crackles. w**k. I'm tempted to try some ballasts from another supplier
  Polo + Micra
i'm not 100% sure on electronics
but i'm sure you might be able to fit a capacitor on the input connector and it might filter the interference out
  PH1 172 Sport
I'm going to try a new base, lead and aerial first and then see how bad it is when the lights are on. It can't be helping that my reception is dire in the first place.
Has anyone ever seen a reception booster for a car like you can get for a tv aerial?
Gaz_
  Extreme mode
Nope. It seems to be the frequency the caps/transformers in the ballasts give off......... If the shielding of the cases is cack, it 'leaks', thus interfering with the FM signal (must be the same). You might lol, but i think wrapping the ballasts in lead would cure it:rasp:
  Polo + Micra
well that's how they suppress rfi with motor brushes lol
are they a complete metal case or are the back just like a resin sealed?
Gaz_
  Extreme mode
Metal case. I work with cctv/alarms and we have suppressors for rfi, but nothing seems to work on the car :( Just cheap components tbh. Done some major google searches on it, and nothing sems to work :(
  Polo + Micra
yeah must be a poorly designed psu for it to emit rfi through a grounded metal case lol
