HID Fitting Guide?
Car  Ford Fiesta ST2
Hi all,
I have just purchased an HID kit for my Clio 182 and wonder if anyone can provide me with or point me in the right direction to a fitting guide!
Regards
Alex
Plug and play basically just puting the ballast inline! You can exaclty put anything in the wrong place except the + and - in which case turn them around!
Then fix the ballast some where job done! should take half hour if that!
My query was relating to how to get the bulbs to fit since the ones in the clio are a twist and fit. I managed to take the clip off the clio light. Was a nightmare to fit due to been very fiddly. Looks much better now they are fitted though. I ordered from HIDs direct which comes with everything you need.
All HID kits should fit directly as old bulbs did, if not there wrong fitment :)
No, it depends what kit you buy. My HID kit required a slight adjustment to the silver clip and the bulb did not sit in the square block as the standard bulbs did, but fitted fine.
