HiD Headlights
  Clio 1.2 2003
Hey guys
Just wondering if anyone knows of any websites were i can find HiD headlights for a mk3 Clio.Have been looking for a while with still no luck. Any suggestions would be great.
SC03OTT
  Octavia vRS
Assuming you still have that 1.2 Clio, Mk3 lights won't fit. You have a Mk2.
  Kawasaki ER6N
Didn't realise on that site you can get anti glare bulbs that enable you to use them with reflective lights means you don't need projectors.
  Clio Dynamique Noir
Thanks matey...quite a bit cheaper than the ones on HIDS4U, you reckon theyre just as good quality? Anyone else bought from here, or ebay?
  Clio Dynamique Noir
Doing this off memory frorm standard bulbs so not the HIDS...but make sure you have the bulbs the right way up in the unit, then if you standover the headlight and look down should be a small hole, big enough for a screwdriver, and should be able to see either an allen key screw or a flat head screw and you just turn that clockwise/anti clockwise whatever you need!! Thats just for the levels, park infront of wall (preferably at night) put your headlights on and see of theyre the right level...hope that helps!
