either the front rad grille or if you can be bothered the front fog light hole/blank.
To remove the standard feed just follow the pipe down and unclip it, there will be a plastic tube type valve. It has a connection on it, unplug it, remove plastic valve, unscrew electrical solenoid from the tube, plug it back into the car, tape or secure away, and pass new ducting through the hole created.
that air scoop idea in the front wheel arch liner is a bit of a crap idea.i left the original feed in and put the hillpower feed through down the side of the radiator.put the airscoop sticking out between the subframe and radiator.will post a pic if i can.
Think Ill have a bash at fittin a feed like JAYs being as Ive got the scoop affair, I reckon Id have trouble fitting that between the rad. and the foggy. If I leave the existing feed in place that leaves me a spare piece of cold air ducting I can use on the wifes BRM
ive left the original air duct in and fitted the hillpower scoop+air ducting,ive just routed it differently to where they suggest.my air ducting/scoop comes out between the radiator and the subframe underneath.
