Horns died
Check your fuse first, the horn itself is infront of the N/S/F wheel, loads of crap can get in there so its a good idea to clean up the connections and see if its getting 12v - if it is and they're clean your horns probably shot.
nope, as its part of the main loom that would mean you would have loads of other problems, its prob just oxidized connections, mine went the other month turned out to be the connections and the horn,
make sure the bolt its mounted with is clean too as this is the earth for the horn, if thats cruded up then it wont work eather,
give the area a real good clean up with a wire brush, sand paper and if it still dont work get a new one
