hosing to fit a valver throttle
Car  Titanium 182
can i buy some samco or simlar hosing to fit a 16v throttle and then turn into a circle so i can fit an encolsed in duction kit i have?
if so where from and how much
Yes you can. I have one on mine, had to make it my self. Just cut a template of the throttle body out on 2-3mm steel etc then weld a piece of tubing (i ve used 70mm) bolt it to the throttle body and there you go. I ve made mine so that i can run a viper on it.
erm its in both the motorsport and performance DT catalogue. u cant order it online.....:-(
quite expensive @ £32 a metre i think it was! but its high quality stuff!
iv got the same but iv re-located the CDA and the angle is now wrong! boo! ill get a pic later on mate if u want?
If any one wants to e-mail me I can mail you back with a picture of the kit. The adaptor we have is £70.00 plus vat retail. Clio sport discount price £59.50 plus vat.
steve and adams
how did you bolt the plate to the throttle body then?
and where did u buy them 70mm tubular steel?
using the existing bolts. I didnt use a bit of tube just a strip of metal bent round then welded.
steve i still dont understand?
also what exisitng bolts connect to the throttle body? its a jubille clip!?
there are 3 bolts on teh TB which usually screw into the original airbox. the throttle housing is bolted via those. ill get some pics sorted for u tomorrow mate so u can see what we mean!
ok"! thanks
as im just getting more and more confused
my car came with a kn on, but iv got the original airbox cant see the bolts or holes tho! :(
