Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Got a 1.4RT and Im not sure how to empty the coolant. Added som Rad Flush to help clean it out but I cant find any drainage point. Is it a case of just taking the hoses off?
Normally a drain bung on the bottom of the rad but its quicker and easier to pull off the bottom hose. If you do get a leak as a result of the rad flush DO NOT use radweld or similar to try and patch it up, that stuff is for bodgers only.
I decided to clean out the coolant coz I got a leak the other day (just as I arrived in Blackpool). Got a replacement pipe from Renault for £30 all in so not so bad. Better than I was expecting (it was the metal pipe that ruptured not a rubber one).
