how do u fit a rev counter to a mk1 1.2
Ok, loomed up wiht the cables will be a wiring plug wiht two wires going to it, these are the two wires you need to connect up to a rev counter, this is if you dont have a rev counter.
These cables are behind the instrument panel, youll need to remove it to get at them. remove the dash top, steering wheel shroud and the bit under the seering wheel, then 4 screws to remove the instrument panel
  Megane 225
yeah but where do the 4 wires go? i got the counter fitted but just havent wirerd it up yet cos i dont know how
  Megane 225
got 4 wires on the back of the rev counter, 1 goes to the dash lights, 1 goes to earth, 1 should go to the positive side of a coil, and 1 should go to negitive side of coil.
have you got a diagram or pic of the wires behind the dash?
cheers
