how do you remove the RS grills and black plastic?
  clio 182
as above,
how is it done? where are all the clips etc?
want to remove the RS grill and the fog surrounds, and grill in the lower bumper? to paint them matt black. whats the best way to do it without removing the bumper as i dont have the tools to do that. and cba too. and where are these clips?
cheers
  Astra 1.9Cdti SRi
Top RS Grill:
open the bonnet and on the top left there is a black plastic screw type, remove that, and the same on the opposite side.
then tap the bottom right of the grill and it will pop off then go right round the grill and pop it out, its easy,
Bottom grill:
really you need the bumper off, but i have managed to do it withouth tho, as i dont have the plastics underneath its easier, so you need to somehow unclip about 8-10 clips on the grill and off it comes,
fog surrounds:
remove the fog light itself, then use a butter knife with a cloth and pop one side of the light and then just pull with your hands, should work itself lose, do the same for other side,
  clio 182
Are the fog surrounds attached to the Fog lights? Or just the bumper.
Sounds easy lol. Will shall c if guess.
Cheers mate for that!
  DCi 100
Fog surrounds just pull out, lower grille just has clips top and bottom iirc, but easier removing the bumper to get at them.
  GONE!!Yozza'd BG 182
i take it these are going to be painted, been looking at ur other thread, would u key the plastic first and use a primer or just paint directly onto the plastic?
  clio 182
The upper grill I just cleaned n painted but repainted dye to me not liking the colour. When I do the rest am just gunna clean, prime n spray coz it's not smooth plastic it should stick fine
VIICarCare
  255, 230, 172, R26
even a quick rub down just to etch the plastic for the paint to stick to is better than nothing
