how is this possible??
Car  v.cheapferrari
how can a Class D Monoblock Subwoofer Amplifier run two 12" sub??
click here, 4th package down - [FONT=Arial, Helvetica, sans-serif]E1400 & 2x12W3-D2 - [/FONT][FONT=Arial, Helvetica, sans-serif]£374.99
thanks for the help - would you recommend me getting this??
[/FONT]
i run 2 12" subs off my class d (mono block) it is only a 1-channel amp
it's better as they give out more power with lower impeadances
cheers
what power rating would i use - 12.5V or 14.5V??
wouldn't the RMS @ 2 ohm for the amp go down, meaning less power for the subs??
no it's goes up as the current would be doubled
i'd say half way between the two voltages
cheers
this is good stuff ye?? i mite order it 2moz so i can get it on thursday, do you think i should?? i had a budget of £400 for 2 subs & an amp, fits perfect i think, so shall i get it??
you need a box aswell to got with that
i got a sweet JL amp can't fault it one bit and had a w6v2 which was sweet but never had an amp to push it at the time
i'm making two single boxes for ma design & technology project that ive started now
ive researched into the correct size & that, so i should make it correct
cheers for the advice, i;m going to ring them to order it 2moz, thanks again
Dual 2's wired the correct way will load the amp at 2 ohms.
This means it works harder and produces more sound.
When your car isn't running the battery will provide about 12volts, when the car is running (which is a good idea when you've amp(s)) then its running about 14volts through the electrical system.
