how to change rear speakers
:confused:how do i change my rear speakers in an 03 clio facelift model i dont want to start hacking away if there is an easy way to do this
cheers andy
should be just take the seat base off/out then you can pull part of side side panel off exposing the speaker, have a search round on here and you should get some more detailed instructions, but its easy when you take the seat base out on each side.
  The Jinx
Just as said. Take rear bench out (lean it forward and pull up) and youll see the small panel that covers the speaker. Pull this off carefully so as not to break the clips.
