How to change the break pads?
Car  VX220 lightning
Hi,
Just wondering if someone could give a step-by-step guide of how to change the rear pads on a 182?
Adam
They are not to bad to change TBH.
You just need to turn the pistons, when pushing the piston back into calipers.
Apart from that, it's pretty easy to see what you need to do.
Thing I found with the rear caliper is that you will need to have a smallish flat head screw driver to slide into the piston.
Oh and make sure you push and turn, I was there for 15 mins turning and couldnt figure out why it wouldnt retract, the only other finndly part is putting the locking pin back in place, did it in the end by opening the pin slighty and sliding in place than clamped it in the pliers to stop it from opeing again.
