how to remove front door panels on a mk1 clio?
  clio mk1 phase 1
alright ppl, im having trouble removing my front door panels on a mk1 clio phase 1. can anyone tell tell me how to remove it? thanks.
  1996 Valver
You will need a set of Torx bits, T20 is the main size I think.
Unbolt the area around the the window switch, about 5 T20's, then pull away and disconnect window switch.
Prise apart the handle and unbolt two large torx's bolts.
Unscrew door release handle (one torx's bolt)
Now un-pop the bottom of the door card and make your way up to the top.
think this is all
