How to remove the heater matrix?
len_beach
Car  E92 M3,172 track car
I need to remove the last bits of sound deadening and spray the interior. Where are the bolts to undo the matrix?
The bolts to undo the matrix are behind the firewall under the wiper motor their 10mm and should be 2/3 of them.
remember to disconnect the water pipes going into the bulkhead
Cracking! Should be easy as the scuttle is off.
Is there a bit of room for manoeuvre with the pipes?
​Cheers
Its the water pipes going into the bulkhead (engine side) under the water bottle, push in the plastic clips either side and pull the pipe off but sometimes they are stiff to come off.
