How to remove window handle?
How do i remove the window handle on my clio 3? Do i pull or is there a clip?
After i removed i the screw in the door opener do i just pull it out?
Is there a complete guide to the clio 3 such as haynes for clio 2?
  Clio 182, Mercedes S320CD
I belive there is 4 clips if im not mistaken. Two on each side which you can release with a flat screw driver.
PLEASE DOUBLE CHECK BEFORE YOU DO THIS AS IM NOT 100% SURE.
