Hubcentric's
  Vantage
oh right.. i am getting these aswell.. so i guess it helped me to :D
but it says this somewere about hubcentrics...
Type 10, fitted onto the hub using the nuts and/or bolts supplied in the kit. The wheel is then attached to the spacer using the oringal bolts and nuts.
so i guess some people provide them.
  BG 182 FF
I thought by having the hubcentric spacers rather than a piece of metal, you can use standard bolts and also there is no faffing about if you take your wheel off at any time. That what I thought anyway lol.
If they are the ones that bolt to the hub, then you won't need longer bolts.
Get them from here to avoid any confusion (choose Type 10).
