im going bald over this clio
  cup and subaru wrx
Hi wondering if i can pick some brains guys!
i have a v reg clio 1.2
problem is the immobiliser light goes out after 5 seconds thats all good i get no spark have changed the coil pack crank sensor at the gear box for a new 1 still no luck
my clio doesnt have the central locking button inside the car beside the gear stick just blank its just a solid key no central locking no sunroof i may add.
today i went and changed half the fuse box an ECU key and barrel and key pick up all 4 things still no luck.
i have changed it all back to how its was the immobiliser light goes out but as before does not spark i have checked the 4 realy thin red wires also all fine....
BEEN TOLD MY ECU COULD JUST NEED RESET ???? any help would be good thanks again
  a low one
The imobiliser is around the barrel as like a black loop so I'm assuming you can just get another immobiliser (scrap yard) and have your ECU re coded? I've bot heard of the resetting but may be worth giving a search on google
  cup and subaru wrx
re-setting the ecu made no change atall any 1 else have any ideas any other boxes in the car that could be an issue.
personaly im thinging i have a broken wire some were in the loom ?????
