172cup
Currently doing a 172 cup conversion on a 1.2 16v ph2.
Dropped engine running gear subframes the lot simple swap. Engines in, Swapped engine and interior loom. Uch ecu the lot.
All wired up and connected ( bar the alarm system I cut that out as its not necessary and the seat air bag wiring.
Turn ignition on, all lights work everything comes on fine, Except the immobiliser light flashes like mad. Can hear a relay clicking and then the Engine/stop light flashes and nothing happens. Tried the key fob ''trick'' while turning the ignition on but no luck.
Fuel pump doesn't prime either.
All earths are connected up, Tried the spare ecu uch and key and decoder ring but still no luck.
