"Indicator stalk attachment" loose. 172 Ph. 1
  Clio Sport 172 Ph. 1
Hello.
The part where the indicator/other stalks are attached to sits loose and rotates on the steering column when using blinkers. Anyone know how to get it tight again? Also what is that part called? Car is a 172 Ph. 1.
Thanks?
Louis
I Park Like a C**t
Hello.
Thanks?
Take the top of the steering column off - it should just pull off. You'll see some screws underneath which are either missing or loose
Ah I see thank you, can't believe I missed those before. Both screws are missing. Do you happen to know what screws to buy for replacement?
