Modern day ecus can cope with some flow rate and/or inlet temp changes, and adjusting the fueling accordingly, but alot of the time you do need to correct the fueling in some way, this can either be by a remap via a decent Superchips dealer or someone like Hill Power or BB, or you can fit an adjustable fuel pressure regulator which will allow you to up the fueling to cope with any lean points you may have (I know Nick Hill has done this successfully after fitting one of his induction kits to a car.... was it a 1.2 16v?? - I cant remember)
