on my 2000 clio rsi 1.6 16v i fitted a k&n induction kit the filter is no good so want to replace it with a closed filter anyone know the bore size of the k&n plastic pipe?
from memory the K4M airbox is right at the back above the exhaust manifold, id look at running a 172/182 or even better a ph1 172 airbox setup with a custom inlet hose
cars in my workshop 20miles away and i dont drive at the moment so cant just measure it
havent got the original airbox and as said it sits ontop of the exhaust manifold. i want to use the k&n pipe and put a closed airfiter on it so it sits above the gearbox away from the manifold and run a air feed to it.
