inlets and a remap
  421 Cammed 172
IIRC In the PFC Article they said.
Exhaust manifold porting larger than the ports in the head.
Inlet manifold smaller than the ports in the head.
This stops the gases passing back. Also the Inlet manifolds should not be smooth sanded when matched, but left rough to add turbulence to the air. Exhaust manifolds must be smooth to allow the air to pass freely and faster.
  2005 Nissan Navara
Inlets should be matched exactly to the head.
The reason why you shouldnt use the inlet gasket as a template is because its larger than the port itself, so using this will end up with the manifold larger than the port, which can make things worse than standard.
  421 Cammed 172
I wish they'd do an article on adapting motorcycle carbs to fit a car engine to be used as throttle bodies - lol
Or is that too much to ask?? :rasp:
  421 Cammed 172
Dan you've worked in these mainstream companies.
Whats the majority of the iTB costs go towards?
Is it more Research and development, Engine management or the actual iTBs themselves?
  ITB'd MK1
All of it. Quality hardware from the start pays dividends in power, and all running in general. Anything but Jenvey TBs are normally a s**t to balance. A well developed loom may seem expensive, but if you try to build one from scratch, you'll make little saving, and the end result will unlikey come close. Engine management if a fair chunk of the cost.
