Inner arms on rack.
JoshOm3
Car  Cup'182/Rs2'd Trophy
Are these main dealer only? If so would anyone know cost, part number.
Thaanks.
No, there are lots of aftermarket ones available too, Lemfodder(sp?) are pretty good for steering components and IIRC there was a code on here recently for a disocunt on them at euro car parts.
You Defo sure euro car parts stock then? Only my mare bought a pair about a month ago and they where too short.
If you ask for clio ones they give you base models ones normally at autofactors, you want to ask for kangoo ones I think it is for them to pull the correct thing up on their system.
*Lemforder.
To change them, you either need a 32mm spanner made thinner with a grinder, or even better a 32mm crows foot made thinner.
*Lemforder.
I just use a proper track rod tool, so much easier, only slight issue though if using aftermarket ones is you then need two tools, as although both the aftermarket and original are 32mm, the ball section the track rod tool goes on is slightly larger on the aftermarket ones.
