yep jus got it tonight from halfords, installed it and it sounds brill and its improved the preformance slightly, not much but slightly. However the fumes coming out my exhaust stink! is this normal?
Yeh i got that a bit, leave it idleing for a while just to adjust itself, if it still persists and you plan on getting a full exhaust system to then book it in to get remapped for the new parts.
doesnt sound good, but when you hit 60mph onwards the car makes a rumble, if you want to see more difference, get a de-cat, i noticed easy acceleration since had it, but now its s**t again (hole in the Downpipe)
well i installed it, left it to idle for 2mins (couldnt wait any longer if u know what i mean) then went on a 15min drive buzzing off the noise lol. Got back home and left my car idling. After a few seconds i turned to my mate and said "f**king hell that one stinks u dirty b*****d" he then turned to me and said "i think its ur car m8". so i went to the exhaust n dam he was right.
Oh another thing. i was thinking of buying the relocation kit from k-tec and i was wondering if this would fit my K&N adapter plate and filter. And if anyone has brought one are they any good?
It will fit, get some rubber resizers from halfords if you get stuck. Double check that your exhaust is all tight, with you thrashing it itmay have worked itself loose, happened to me before and it was a rough stink.
the smell is more than likely from the catalyst as u have been thrashin the nuts off it fella.Ull notice an increase in fuel consumption as ur a feeding more air into the engine and the ecu learns from this and throws more fuel in to compensate otherwise your engine would run way to lean,(not enuff fuel in the cylinder)
exhaust smell :S didnt get that with mine, dont think id bother with a re-map fella becaus its only a 1.2 after all, id go for a de-cat and a exhaust will sound better and gett a little bit quicker on the acceleration.
well its not smeeling anymore, just using alot of fuel lol! iv had a thought. Im not going to get a remap, i might get a new engine put in, say 2.0 16v? wot do you guys reckon?
