Installing PS2 and monitor
How would i go about installing a playstation 2 into my car, i.e how would i power it? would i need a power inverter?
Also how would i power a 7" monitor, can i simply run a power cable off the battery with a fuse like i have done with my amp?
And finally will it be ok to run a ps2, monitor and amp off my current battery. I have a 1995 1.4RT.
Cheers guys.
Lol
I was thinking of having a similar set up in my car, but purley to watch DVDs on, was thinking maybe screens mounted in sun visors, less obvous to a theif then
run the screen off your amp
the inverter off your amp and the rest of the connections are simple
its gettin the sound throught all the speakers whats hard if your headunit doesnt have an input like mine then its a bit of a ball ache but still possible
Can you not use an RF modulator?
Or if you have a headunit that has a cd changer input then get a converter lead.
Also with the power converter, you can get a 12v conversion for the ps2 for under a ton, which is a lot better and neater than a invertor. depends if ps2 if permanent for car as to whether you would want to do that
