Interior removal, How to get lower steering column case off ?
  clio 172
I'm currently in the middle of removing the dash from clio 172.
Its all free now, i just cant remove the lower steering column plastic off !
The cruise controlstalk is stopping it from coming off !
can i remove the cruise control stalk somehow, anyone done this ?
ive only just got the car and a newbie with clio's !
any help and advice would be great
cheers
mike
  Astra 1.9Cdti SRi
top part you pop off, pull the steering wheel down then pop the rear of the top cover off,
to get the bottom part theres 3 torx screws, which you need a Torx 25/26 bit to remove them.
the controls unit need to be pushed out from the top, theres like a little clip you push in and you pull and it should pop out :)
