Fishfire
Clio 172
The last couple of weeks my Clio 172 turbo has had an intermittent starting issue which I think is actually two different issues.
First issue: occasionally when you try and turn it over, all I get is clicking.
I've found that depressing the clutch pedal will, 9 times out of 10, release this and it will turn over. It's like the clutch is sticking. Still not sure why this should be the case?
Second issue: once it does turn over, occasionally it just won't start.
It will turn over 4 or 5 times and cut out of its own accord despite having the key still turned. i.e it doesn't continuously crank but cuts off after a few cranks.
It seems like the fuel pump isn't priming.
The pump is a brand new Bosch item for a phase 1 with the fuel return that's needed for the turbo set up.
It played up this morning so we tested to see if the pump is getting power, but could only read 10v getting to the pump connector.
Things I've done:
- brand new Bosch fuel pump ( part no. 0986580204)
- brand new Lucas starter motor fitted in the last week.
- all three small black relays changed for new items ( starter, injectors and fuel pump relays I believe?)
- Brand new crank position sensor fitted in the last week.
It's not the immobiliser that I can see. I have two working keys, which both have the same result when it starts playing up. The imobaliser light also isnt flashing, indicating the car is imobalised
This has got me scratching my head......anyone experienced these types of starting issues? All the usual suspects have been changed for brand new items.
I'm half tempted to change the Bosch pump for a Walbro item, which was a mod on my list to do anyway but other than that......🤷
Ideas?!
Things I've done:
Ideas?!
