Hi Theo,
As Fubar says, speak to Matt at MT Audio on here (when you become a full member!
) I bought my unit through him and had it resting in the central cup holder section for a while.
Then later, a mate of mine who's handy with wiring and a soldering iron made the cable that goes from the Aux port on rear of the head unit, much longer. This enabled me to run the cable behind the dash and at the rear of the glove box, there's a small plastic panel that you can pop out. I cut a small nick out of the edge, passed the cable through and clipped the plastic panel back in place - the small nick I made, not crimping the cable in anyway.
The iPod is now out of sight and work perfectly with the standard 182 stalk controls. However, mine only works with iPods - it doesn't properly work with iPhones. When conencted to an iPhone, it doesn't charge it and it has a weird issue of skipping tracks or completely going back to the start, halfway through a track.
Whether or not there's a newer version of the adapter that supports iPhones, I'm not sure.
D.
