Jacking 182 up on pebble drive
I need to replace my pads, and where I live is a pebble drive (large pebbles) although most are embedded in the ground, there isn't much loose stuff. I've got a jack and axle stands.
I was thinking a 3x3ft bit of ply wood, 18mm thick to spread the load. I'd get 3, 1 to jack and then can rest the stands on the other 2, do 1 axle at a time. I can also throw the wheels under the car. I won't even need to be under the car.
Thoughts?
Crybert
  Cup 172
That'll work mate. Stick some stops/bricks behind the rear wheels too but wood to already the load will be fine. I'm assuming the driveway is flat?
Louis
I Park Like a C**t
If the pebbles aren't too deep, maybe scrape them to the side to make a nice square base? Otherwise a big piece of wood to spread the load would be fine.
Loads of my final year project work has been on axle stands/jacking up vehicles and it's scary the amount of people who have experienced falling cars from improper lift. 1 in 4 IIRC.
thanks guys, put my mind at rest. 18mm be cool too? Otherwise it's to the builders merchants not popping to wicks after work
Of course it's level, I'm not a mentalist!
