jvc AVX1 will it work ?
  Clio_Smart
Im thinking of buying a jvc AVX1 but once its all set up is there anyway i can get the audio remote control on the steering wheel to work with it as i know when you put in another headunit other than the standard one it doesnt work.
  Megane R26
InCarTec produce convertors. Basically 2 part systems, a little loom for the car and one for the head unit, so in your case you need one for the clio and one for a JVC HU. Just checked and the AVX1 is supported by the JVC cable, below are links to the 2 products you need:
HU adapter - http://www.caraudiodirect.co.uk/product_info.php?products_id=3484
and either...
Car adapter
if your car has a dash display - http://www.caraudiodirect.co.uk/product_info.php?products_id=3474
or...
if your car doesn't have a dash display - http://www.caraudiodirect.co.uk/product_info.php?products_id=3473
Hope that helps
  Clio_Smart
All that just to make the audio control work with it.
If i aint dont bother having the audio controls for it can i just install the jvc product and use it as normal or do i still need them products for it to work ?
I can just install and im away ?
  Megane R26
Well you buy one bit for the car then the other for the make of head unit. Only a little bit of wiring. It basically means you don't lose the dash display and steering controls, as these are all done thru the yellow iso plug that goes into the back of the standard radio. But you can use the JVC fine without them, but if you do have a dash display then you will lose this.
  RenaultSport clio 172 mk2
these are great headunits, i had one in my vtr, can get mp3 dvd format, 900 songs on the one disc, (ipod get to fcuk haha)
koi
  Audi S1
and either...
Car adapter
or...
Hope that helps
Do you need to take the dash off to fit this?
