should be a seperate cable covered in like foam padding stuff. will be in the dash somewhere probably just fell down out the way?Hi all,
I have just bought JVC AVX1 off hooky108.I have fitted it but i cant get the radio to work on it ??? I dont know which lead to put in? Do i need to buy some for it to work???
ive just bought one of these also, i cant get it to go in! there are so many wires coming out the back that i just cant push it in, i must have been trying for like an hour. There is no space behind there....
yeap
what cant u find for the radio mate? the arial cable from your car or where to plug it in on the unit?
if your looking for where to plug it in its thte long black plasic thing that it plugs in too, you may need an adapter for it
You sure you need an adapter? Fitted mine the other week, 2001 Clio, and didn't need one...
What I noticed was that when fitted the face doesn't sit flush with the dash, sad but what can you do.
Cheers for that mate I have found the stupid wire now... it was stuck up the top.
So what did you connect the parking wire too? and how did you do that?
