Karcher 2.14 help
  RB Clio 182
Hi, i have a baby karcher 2.14 pressure washer which was working fine until recently, i tried to use it at the weekend and it wouldnt work.
You can hear it as normal pressurizing when the hosepipe is connected with the tap turned off, but when i turn the water on to use it, it stops the pressurizing noise and it wont spray anything out, if i turn the water off again the noise starts up again like normal!
I have tried bleeding it but that hasnt worked, any ideas anyone?
