182
Hi guys,
I have 2 problems with this,
The first being the hose has finally worked a slit into it meaning when turned on the water squirts out and the gun becomes useless. It looks like the full hose/gun are one piece so will need to replace the full part, does this sound likely? I would have though the hose would of been separate from the gun part.
The other problem is that when turned on, it makes a pulsing sound, the noise is on/ off on/ off, then when spraying the sound stops completely. Im sure this isn't normal but not sure what it could be.
Karcher 411 A is the model
Any advice from you lot in the know would be greatly appreciated.
Austin
Austin
