Knock and squeak
Car  Megane R26
Hi guys and girls,
I have a couple of annoying noises coming from the car which I was wondering if you could help with the first is a slight knocking noise when pulling out of junctions at slow speeds with not quite full lock?
The next noise is a squeak when turning right over bumpy surfaces?
The car is a 2004 182FF, recently fitted with new ball joints, top mounts &brakes all round.
They don't appear to be leaking at all, will check again tomorrow though.
Any other suggestions people?
If they're just standard top mounts then yes, the washers raise them up 3mm so they don't catch. I've just bought a set and it's solved the creaking on full lock/turning over bumps. Still get on occassional knocking.
I did the washer fix with my old top mounts but still had the knocking noise so thinking this could be more of an issue....just a little reluctant to pay for a driveshaft straight away....
