Knocking out hub flange
Louis
I Park Like a C**t
Can I just knock out the flange with a socket and hammer?
I'll be welding out the bearings and wanted to save myself a trip to a garage to get them pressed out as wanting to paint the hubs before new bearings go in.
  PH2 172
Better to paint the hubs after the new bearings have been fitted?
  renault clio 1.4 16v
well i got a 12 ton bottle jack that i used on a home made press and i needed to extend the poll to push those buggers out... so yea you could do it with a really big hammer... problem is how to keep the hub level, I used a bunch of off cuts, you could do the same. you could also try using a big bench vice if you have one. as for getting the inner race of the bearing off the hub, just cut a slot into it using a grinder ( not all the way through the race) and give it a whack with a hammer and chisel, the race will crack and you can just slide it off.
