Good man, I didnt realise it was a members only link tbh!
I think from looking at the front coilovers side by side they are quite like the vmax coils, the fronts of the KTEC's go down so low its unture but due to not being able to adjust the dampening you wouldnt even be able to run anywhere near that low as you would be rubbing around corners like f**k. I have my fronts 70mm from the bottom of the coil and I still hit when hard corning. Also the other downside is the rears do not go as low as you would expect coilovers to imo, the vmax go slightly lower due to using different springs. Im using my old Gaz Gold coilover springs so the height is perfect for me.
Oh you have a 182, if its a 182 cup you cant fit them anyway!
