ktr camshafts
L
leeboy182
are these cams any good they seem really expensive ?? Can anyone recomend any other places that sell cams? And what difference does changing the vvt setup do which setup is best?
  197
Depending on the cams VVT rpm needs to be raised a couple of hundred rpm.
It needs to stay enabled otherwise you loose a lot of midrange torque.
L
leeboy182
oh ok I see so does that mean it better to go for the cams where you keep your existing vvt pully etc?
