KW rear drop?
Car  Exige S1 + Honda S1
as was being discussed in other thread, you can't you remove the height adjuster?
Anyone fitted shorter springs?
here is a pic on lowest setting>
Looking at yours, they are a different spring to the ones I was describing so you 'could' remove the adjuster but I'd put the rubber washer on the bottom from the OE springs to stop any rattles....
Mine shot from the rear...
(Spring not sitting fully on platform as car is on the ramps)
Your spring is the type I meant would'nt work Dan. It's linear so would sit well pissed on the axle.
Phil, scrappy will give you one if you're that bothered about 5mm, lol!
you can get lower, my rears have a helper spring on. and kw definately do a whole range of rates and lengths. i'm not sure if the comprtition stuff will transfer to the road stuff though?
My spring works fine though? lol
Few of us on these springs have the height adjuster removed.
