KW V2 Collies for 182
  ITB BG 182
Wheres the best place to get these from for cost?
Also how do i tell if my car is cup packed or not?
The Boosh!
ClioSport Admin
  Elise, Duster
You can't get them for a cup packed 182. Unless you machine out the holes that is.
  ITB BG 182
ok how do i tell if my car is cup packed or not then? i dont think it is but i want to make sure before i order alot of money worth suspension.
  500 Twinair
The best way is to measure the suspension struts, the cups are 60mm and I think the non cup is either 56/58mm.
Kw for the non cup only, h&r is available for the cup packs.
  ITB BG 182
Ah, i just thourght there was some way to tell by the vin vumber or the little sticker on the inside of the drivers door.
  Evo 8 MR
You need to remove one of the front wheels and measure the distance from centre to centre between the two big bolts that hold the bottom of the shocks to the hub.
You can't miss them they're virtually right in front of you.
