lambda , post or after
  350z , clio 182
I know this kind of topic has been discussed before but just want to ask
check engine light comes on usualy lambda sensor , but which one is it more likely to be the one in
front of the cat or the one behind ? any ideas
G.
MarcB
  Too Many
I might be wrong but I'm going to say the one after the cat as I'm sure thats the one checking for clean air.
I might be wrong tho.
  renault clio 1.4 16v
both can bring up the light, however the pre lambda sensor (before the cat) is used for the fuel mix, the post lambda dosnt influence the mix and is just there to make sure that the cat is working...
  350z , clio 182
thanks ,runs fine but gona have to get it plugged in anyhow to find out exactly what's going on, anyhow least of my worries now think my defaser is on its way out as its started doing a bit of wining
and when I accelerate it wines so got to investigate this as well , don't you just love French cars!!
there nearly as bad as Italian cars! G
