Lambda Sensor
Car  Yozz'd up 182
My emissions light came on a few weeks ago just before a service, had the garage look at it and they told me it was the precat lambda sensor.
He gave it a clean and put a block or something on it but said if it comes on again il have to get a new sensor.
Guess what? It came back...
So i wanted to know if you can change it yourself and if the light will go off itself and where to get the cheapest sensor. Its for a 04 1.4 16v.
thanks
Yes you can change them yourself, its just a simple procedure off unscrewing the old and bolt the new one in, if it is the pre-cat lambda by putting a new one in place the light should go off,
try. www.eurocarparts.com just type in your reg and it will bring a list of parts up :)
Yeah easy fix, might need a lambda socket if its fiddly.. you can get plug and play ones or universal 4 wire ones that you splice into you're old plug for about £17
