Laptop with XP
Could anyone point me in the right direction for a laptop with Windows XP? I'm looking to spend around £400 and the laptop ideally should be comfortable with Photoshop/AutoCAD. To be honest I dont know where to start looking. Pretty sure I want XP, unless anyone thinks Vista is definatly worth having?
Thanks for any help! :)
Darren S
We bought this one last week m8 for work and it seems a good piece of kit. Not sure on the silver fascia, but the screen is very, very good.
http://www.pcwb.com/catalogue/item/TOSNBK10
Comes with Vista Business installed on it, but there's an XP CD in the box with all the Toshiba's drivers, etc. Pop that it and it installs XP for you instead - no hassle.
As a nice change as well, it's not bogged down with 5 ISP links, 3 AV packages, etc. Just XP Pro with Service Pack 2.
A good buy, imo.
D.
That looks quite a good deal. thanks! How adaptable are laptops for upgrades? I know with desktops you just whip the side off and replace the part. But laptops dont look quite that simple?
Darren S
You're right. They are not that upgradable at all. Memory is easy (and cheap) to upgrade, but things like graphics are pretty much a no-no in upgrading.
There used to be some proper high-end laptops with decent graphics setups onbaord, which no doubt would be good for your Photoshop/AutoCAD work. But unless you go down the route of eBay, I don't think you'll find anything of that type of spec for your budget?
Money no object, you could always consider....
http://h10010.www1.hp.com/wwpc/uk/en/sm/WF06a/321957-321957-64295-3329741-3329741-3784202.html
The nVidia Quadro or ATi FireGL (depending on model) card would be perfect for AutoCAD. Comes in at around £1,650+VAT mind - lol! :)
D.
Thanks a lot for your help Darren, think im going to go for the Toshiba. When payday rolls round! Friend of a friend is a manager at Currys... 10% discount FTW :cool:
  Better than yours. C*nt.
Not true at all - it's much more scary to upgrade but to say it's not upgradable at all is a sweeping AND INVALID statement :) hell it's not even that difficult in most cases, just got to do the research!
MXM means that on some laptops, graphics is indeed upgradeable (although this never really took off as it does take more space to stick an MXM module in than it does to solder it to the motherboard!) but even without it, models such as Dell's Latitude D620/D630 are upgradeable in the sense that within an hour and for about a ton, you can swap the motherboard for one with the nVidia chip instead of the Intel IGP - which I'd say was an upgrade.
Screens are upgradeable - as a product gets to the end of it's life, it's often extended by swapping the panel for a better resolution one - when the XPS 1530 came out the panel I've got on mine wasn't available - tis now and very reasonably. Can pick it up on eBay too, seperate, and it'll swap over as long as you're gentle. Makes using it much more pleasant usually!
Processors are typically very easy to upgrade - some models make it a b*****d job to get to but on my XPS it's a cinch. It's only Ultraportables that tend to have the CPU soldered to the motherboard - again though as later revisions come out with different chips you can buy the motherboard and that gives you the option to do that.
Memory is an obvious one - SODIMM is a standard now for laptops, with only very very few deviating from this.
Hard disks - again depend on model but typically just two screws and slide out, which is another upgrade you can do in your spare time!
DVD/CD drives - if when you bought the laptop the Blu-Ray drive was a £500 option, but now there's one on eBay for £100 that you want, the drive is usually a single screw under the keyboard at worst - another upgrade...
The trouble is consumers are scared of laptops, thinking they are an immense feat of engineering and much more fiddly than desktops. Difference is if you're methodical and sensible you can take a laptop apart and put it back together inside an hour... In my time I've retrofitted wireless to laptops (that didn't even have the aerials!), replaced screens, replaced motherboards and swapped processors - allsorts.
However - the Toshiba posted does appear to be good and as much as I hate them for their shite kit in the past, their latest 'break it and you get it fixed with your money back' isn't to be sniffed at...
