Launch control
Thats got anti lag too the turbo wouldnt spool with just launch control as theres no load
turbo wont spool with launch control you could take a turbo car stick it in neutral and rev it to 6k you wont see the boost gauge make anything but vacuum
that skyline will have mild ignition r****d, if it was agressive anti lag it would bang like f**k
Surely if the throttle is wide open but the revs are being held back by ignition cuts (like a launch control system can) it would start to produce boost?? I maybe wrong as Ive never owned a car with either.
No because you won't be getting the quantity of hot exhaust gasses needed to spool the snail up, hence the r****d and burning it in the manifold instead to produce the desired effect.
Sounds f**king awesome even burbling past
I want my 9 points to go away so I too can have panty dropping boost
God designed boost for winners. Therefore if you don't have boost then you're a massive f**king loser FYI.
Launch control is optional for bi-winning. Anti-lag for tri-winning.
<iframe width="960" height="750" src="http://www.youtube.com/embed/qGSj7ZLzZn4" frameborder="0" allowfullscreen></iframe>
Both boost and N/A are awsome.
Those skylines are great,but so is the new 6 litre V12 lambo aventador...
